Desmog components (4 Viewers)
Possibly a stupid question, but do you have a blocking or sealing nut for the earlier manifolds without the two bolt egr conenction? If not, I have a later manifold, but would prefer to use the original. Thanks!
RookE, yes if it is 3/76 newer you'll need the parts listed. Would be a good idea to have a look up at the bottom of the exhaust manifold to verify that it has the later type 2-bolt flange and not the giant metric compression nut fitting.
$30 EGR
$15 gasket
$10 caps&plugs
$6 Priority flat rate postage
$61 total
Sharp eyed observers will note that as of mid-January, USPS postal rates went up, but only by $1 for the small flatrate box.
Yea, that's a stoopid question. ;)
Only because the later 3 piece exhaust manifold is so much better. If one of those is available, swap it on now, rather than messing with cleaning up an early mani, only to have it crack open next week.
Guess I'll have to drill that broken stud after all, then. Ha. Thanks.
Zekerd, you are correct sir, that's what is needed for an 81 2F and no OEM PS pump
Plugs- $10
EGR block $30
Gasket $15
Postage $5
total $60
Jim,
Meant to reply. Got all the parts quickly. A pleasure doing business with you
All current paid parts have been shipped.
Sold the last EGR gasket, but more are on order.
Everything else in stock.
Jim...got the stuff. Thanks! Sorry for the rookie question...but I may have misinterpreted your last message about being sold out of gaskets and thought you did not ship that part. Is it correct to say that you ship the gasket and block in the same package. Upon closer inspection it looks like the gasket and block are linked in the same small plastic bag.
Kevin
Great. Sorry to be a bother.
On a separate note...what is your current turnaround time for a carb rebuild? Any better time than others? I am VERY interested in getting it done and figured I can get at it during this desmog work.
Thanks as always.
Jim - I am hoping to get the carb out and shipped by the end of the week. Would that work? If so...where should I ship? Payment up front? Any other instructions?
Thanks in advance.
Jim - My carb is out and all packed up. I may have made a critical error in assuming you can help with the rebuild. Please let me know if I can ship to you or if I need to look into other options. People say you are the Carb Whisperer....
Thanks.
