'Deleting' multiple fuel filler pipes KZJ78
uk
One job in the pipeline (excuse the pun) involves removing the fuel tank. I have never seen a set up like it. Multiple pipes going to and fro the tank from the filler neck. I am used to the main filler and a single breather pipe. My question therefore is can I 'delete' the other pipes and have a simple filler and breather combination. Why are there so many pipes?
Graeme
I wouldnt touch it unless I fully understood it. It always works, never fails and has no effects on HP etc. You may even find there is a legal requirement to keep it intact.
On my diesel thee was a bewildering array of pipes too.
Some were related to injector leak pipes.
I made no attempt to fully understand the set up and simply replaced the tank, hoses and some of the pipes.
Here's the list for all the tank related stuff from Toyota.
022AHOSE, FUEL(FOR FUEL EVAPORATIVE SEPARATOR)
95332-06010*H,L=80
1​
$2.73
95332-06020*H,L=150
1​
$7.20
95332-06030*H,L=280
1​
$11.27
95333-06022*H,L=220
2​
$21.39
77023​
FILTER SUB-ASSY, FUEL SUCTION TUBE
77023-22040
1​
$16.13
77031​
CAP ASSY, FUEL TANK
77310-35061
1​
$33.88
77031BGASKET (FOR FUEL TANK CAP)
77316-12050
1​
$5.46
77035​
CABLE SUB-ASSY, FUEL LID LOCK CONTROL
77035-90K02
1​
$43.49
77035ACLAMP (FOR FUEL LID LOCK CONTROL CABLE)
82711-12200
1​
$2.41
77037​
LOCK SUB-ASSY, FUEL FILLER OPENING LID
77037-90K00
1​
$20.76
77100​
TANK ASSY, FUEL
77100-60280
1​
$672.96
77100APLUG(FOR FUEL TANK)
90341-20004
1​
$5.57
77100BGASKET(FOR FUEL TANK)
90430-20007T=2.5
1​
$1.34
77100DHOSE, FUEL, NO.1(FOR FUEL TANK)
90445-22011長さ=220
1​
$10.40
77131​
BRACKET, FUEL TANK FILLER PIPE SUPPORT
77131-90K00
1​
$8.70
77201​
PIPE SUB-ASSY, FUEL TANK INLET
77201-60200
1​
$179.54
77206​
TUBE SUB-ASSY, FUEL TANK SUCTION
77240-60100
1​
$64.96
77206AGASKET (FOR FUEL TANK SUCTION TUBE)
77169-14020
1​
$4.78
77213​
HOSE, FUEL TANK SUB INLET
77213-60040
1​
$33.53
77286​
PROTECTOR, FUEL TANK INLET PIPE
77277-90K00(11/1984 - 07/1987)
1​
$85.83
77277-90K01(08/1987 - 12/1989)
1​
$29.14
77290​
SHIELD ASSY, FUEL TANK FILLER PIPE
77290-90K00
1​
$36.14
77293ASHIELD, FUEL TANK FILLER PIPE, NO.3
77293-90K00
1​
$23.05
77308​
COVER SUB-ASSY, FUEL INLET BOX
77305-90K00
1​
$53.02
77308ACUSHION(FOR FUEL INLET BOX COVER)
90541-05018
2​
$2.21
77322​
KNOB, FUEL TANK CAP
77319-90K00
1​
$9.96
77338ABRACKET, FUEL TANK CAP LOCK CONTROL ROD
77338-90K01
1​
$11.74
77366​
SPRING, FUEL FILLER OPENING LID HINGE
77366-12010
1​
$2.73
77367​
STOPPER, FUEL FILLER OPENING LID
Not applicable
77378ACOVER, FUEL FILLER OPENING LID LOCK
77378-90K00
1​
$7.67
77387​
RING, FUEL INLET BOX
77391-32010
1​
$2.25
77606​
PROTECTOR SUB-ASSY, FUEL TANK, NO.1
77606-60030
1​
$326.02
77611​
BAND, FUEL TANK
77601-60080
2​
$84.57
77611APIN (FOR FUEL TANK BAND)
90240-10025
2​
$3.52
77631​
BRACKET, FUEL TANK, NO.1
77614-60050
2​
$37.88
77632​
BRACKET, FUEL TANK, NO.2
77625-60020
2​
$44.72
77675BBRACKET, FUEL TANK FILLER PIPE PROTECTOR, NO.1
77675-90K00
1​
$6.72
77676BBRACKET, FUEL TANK FILLER PIPE PROTECTOR, NO.2
77676-90K00
1​
$8.70
77701TVALVE, CHECK (FOR MAIN FUEL TANK)
90917-10020
1​
$55.71
Graeme
Remember the fuel tank has the important job of serving to cool the injection pump and injectors. The fuel return is critical to this function. Remove that and you'll cook your injection system.
Remove some of those other lines and you might have problems filling at the pump (fuel displaces air; air has to go somewhere). Also, when driving, the tank can build a vacuum as fuel leaves if there is not a proper breather. This can starve the lift pump in the injection pump.
In a nutshell, don't change anything!!!
