VanGo said:Year - 1997
Motor - Normally Aspirated
Head Gasket - PM'd 1/2009
Radiator Type: OEM
Coolant - 50/50 Toyota Red/Distilled, No additives, Rear heater bypass 1/2009
Tires - 285/75R16
Gears - 4.11
Fan Clutch - Late blue hub, 15k cst, 7/2010
Aux. Fan / Size - No.
Ambient Temp - 87˚F
Air Conditioner - On, High/Med.
Gauge(s) - ScanGauge II/Stock set
Coolant Temps - 184˚F-186˚F highway, 190˚F idling, on ScanGauge II
Other Comments: ARB bumper, IPF 900 XSDs, IL License plate, Safari snorkel
if you keep up with the "what did you do to your 80 this weekend" thread, you can find my experience with a DIY blue fan clutch modification. I held on to my black Toyota "black hub" clutch for a long time, filled with with 15K to 30K cst fluid over the years. I did this because Tools (RIP Kevin) always sung the black hub's praises.Year-93
Mileage- 230,000
Motor-obd1 1FZ-FE
Head gasket-I believe original, no indication of replacement.
Radiator-plastic tank Toyota replacement, 5-10 years ago.
Thermostat- new Toyota replaced 3000 miles ago.
Coolant-flushed 3000 miles ago, replaced with zerex asian.
Tires-315,75,16
Gears-4.88
Fan clutch- new, un-modified blue hub
Ambient temps locally- 60f (current temps as coolant temps recorded)
Gauge- Auto Meter
Coolant temps- 185-190 driving w/o A/C, 190-195 driving with A/C on.
Idle is consistent 180 w/o, and 185 with A/C
My numbers seem slightly unusual bc my idle temp is always lower than when driving. It always returns to 180 in a few minutes after stopping, even after having the A/C on and temps reach 190-195 driving.
Might add an electric fan to use with the A/C this summer. Also I’m considering putting in some hood vents, I can see a 5-10 degree temp drop from idle temp when the hood is open.
Thank you, I will strongly consider modifying my clutch first.if you keep up with the "what did you do to your 80 this weekend" thread, you can find my experience with a DIY blue fan clutch modification. I held on to my black Toyota "black hub" clutch for a long time, filled with with 15K to 30K cst fluid over the years. I did this because Tools (RIP Kevin) always sung the black hub's praises.
I've had a spare blue for a few years, did the 95* timing mod and filled with a mix of 20 and 30K cst fluid. Its crazy how well it worked. I share this with you because your 93 is identical to my 94 and the details you mentioned are similar to those I had prior to the blue hub.
After comparing the black vs the blue, the black offers more resistance even with a lighter CST fluid. Naturally, I thought this was an indication the black would outperform the blue hub. I was presently surprised by the results after installing the blue. about 10-15* difference.
forum.ih8mud.com
Year: 1995 FZJ80Year - 1997 LX450
Mileage Original blew up (New Motor had 120k before I resealed it) stripped down to block and new gaskets and hoses to finished motor.
Motor - normally aspirated
Head Gasket - OEM New
Radiator - New OEM
Thermostat - New OEM
Tires - 275/70/16 Stock
Fan Clutch - Wits End Blue Hub
Ambient Temp - 80 F
Air Conditioner - On HI
Gauge(s) - Ultra Gage
No Lift, it’s just a stock LX with a resealed motor. Original pistons and crank and original head and valves.
Coolant Temps - 176 Before I flushed the Tranny (fluid looked good) and now it runs at 172.4 all the time but I live at sea level and it never sees hills or mountains. It will climb up to 176 in traffic and iv hit 181.5 while driving on the soft sand with full tire pressure lol. Highest iv seen was in the summer on 105 plus days with 100% humidity and A/C full blast and it ran at 186 but never went higher even sitting in stopped traffic. My dash needle sits just a hair lower then half, and comes up it half in traffic and such.
It also gets 16 mpg city and 18 mpg highway somehow...
your temp @ idle and traffic points to a tired or insufficient fan clutch. Try thicker oil in the clutch, i would start @ 15k and go from there...d
Year: 1995 FZJ80
Mileage: 246k
Motor: NA
Head Gasket: NEW, replaced by TorFab @ 242k
Radiator: New OEM 965-97 aluminum @242k
Thermostat: New OEM at 242k
Coolant: 50/50 red distilled
Tires: 285/75r17
OEM diff gears / SUMO Tcase gears
Fan Clutch: Blue Hub MOD from RedLine Land Cruisers, new at 242k (now I know I could of just done this mod myself and saved A LOT of cash!!)
Gauge: ScanGauge II
**Incredibly frustrated with how warm this runs compared to others on here that just seem to exist in the 180's - what am I missing??**
Seattle, WA temps - around town the rig warms right up to 195 degrees and will idle up to 200 at lights. On highway it will sit in the high 180s to mid 190s only going above that on long climbs.
With how new everything is from TorFab, should this rig run cooler? Would love opinions here..
Thank you @Marco Lauyour temp @ idle and traffic points to a tired or insufficient fan clutch. Try thicker oil in the clutch, i would start @ 15k and go from there...
