I went to HD today to get some 5/16x2.5 galvanized hex cap bolts. Had 2" and 3" from Lowes and McMaster respectively, but really needed 2.5.
So I start putting the project together and the first bolt & nut goes together fine - but I thought it was odd that I had to tap the bolt through with a hammer, when the lowes & mcmaster bolts slipped through with no problem.
Same thing with the next bolt - had to tap it through. Hand started the nut, and the galvanized nuts and bolts tend to be a little tight, so I put the rachet on it. Half a turn and it got really hard - cranked a little further and decided this was way beyond the galvanizing binding things up. Maybe I crossthreaded it?? Tried another - very careful to start it straight but damn near stripped it by the time I gave up.
I tried a few more bolts by hand - about 1/3 of them would assemble and the rest would bind up tight. The nuts were from McMaster and worked fine on their bolts, the Lowes bolts, and some of the HD bolts.
I've been buying hardware for 25+ years and I've never encountered this sort of out of spec defect before. Home depot has moved further down my sh|t list.
I returned all but one of the HD bolts - kept one to do some measurements on if I can find my mic. Lining it up against the other bolts, the thread pitch is definitely the same, and there's nothing obviously wrong - like globs of galvanization material or damaged threads.
edit - should add that the McMaster nuts & bolts and the Lowes bolts are all galvanized also.
What really bothers me - if they can't get something as basic as the dimensions right, how can you trust them to get the metallurgy and other less obvious stuff right?
