So I've been troubleshooting this one for awhile now and have narrowed it down a bit with a recent rear axle service.
Symptoms:
There is a very loud moan/grinding sound when decelerating from ~65 MPH. If I give it a little gas (as to engage the drive line) the moaning stops. Slower speeds either don't have it or aren't audible....I mainly get it when exiting the freeway.
I had the rear torn apart this week to repack the rear bearings as the seal had been compromised and there was a slight wobble in both the tires. So this is all after repacking the rear bearings and eventually putting in new fluid in the rear diff.
Things I've done:
Dropped the front Drive Line, locked CDL...( I did this a few months back) the sound was still there.
Dropped the rear Drive Line, Locked CDL removed both rear axle shafts, NO NOISE.
Put the Axle shafts back in, filled diff with new oil....NO NOISE.
Replaced the Drive Shaft, unlocked CDL....the noise is back.
And for s***s and grins...locked the CDL....NO NOISE!!!!!
WTF is going on here? I didn't want to drive too far with the CDL locked, but from one exit to the other, I didn't get the noise when I normally would.
I need to replace one of the U-joints in the rear driveline...it has a little slop, but not sure if it is enough to really cause that much noise. I packed it full of grease just before going out to test it.
Ok, so this is the point that I rely on all of you for your vast knowledge and experience. Let the questions and ideas flow. Thanks for your help.
Symptoms:
Things I've done:
