Dashboard ("panel sub-assy, instrument") replacement - HZJ75
California
I'm going to update my '93 HZJ75 interior from Sable to Oak. There are a few options for the "instrument panel" (aka the big metal dashboard shell) and I'm not sure which part # is right for my truck. Truck does not have factory locking diffs but I'm not sure what "accessory meter" refers to. Is it the little pod that sits on top of the dash with an altimeter/inclinometer/etc.? Hoping someone can help clarify.
FWIW, I do eventually plan to add F&R (non-factory) lockers but not until I swap axles which is still a ways off. Would love to use the factory locker switch when I do so. Not sure if that factors into this decision.
I'm surprised there are 3 different part #s .... figured there would only be 1 that works with all configs. Any help is appreciated!
335530155301-60212-E10101.1995 - 07.2000PANEL SUB-ASSY, INSTRUMENTFZJ75,HZJ75,RJ77..RHD..5F..(ARL,GEN)
W(DIFFERENTIAL LOCK & ACCESSORY METER),LT.OAK,TRIM4#
299.49 USD
3455301
(IRRG)
55301-60291-E10101.1995 - 07.2000PANEL SUB-ASSY, INSTRUMENTLJ79..RHD..STD
FZJ75,HZJ75,KZJ77,LJ72,RJ77..RHD..(ARL,GEN)
W(ACCESSORY METER),LT.OAK,TRIM4#
299.49 USD
355530155301-60192-E10101.1995 - 08.2006PANEL SUB-ASSY, INSTRUMENTFZJ70,71,75,78,79,HDJ7#,HZJ7#,RJ77..RHD..5F..(ARL,GEN)
W(DIFFERENTIAL LOCK),LT.OAK,TRIM4#
298.38 USD
Correct. Accessory meter is the panel on top of the dash
thanks for the confirmation! Wild that there are 3 different versions ... seems really inefficient. Wonder how different/interchangeable they are, and if I should get the one for locker (and accessory meter?) in case I want to add either of those items later. You ever seen the various versions in the flesh side by side by chance? Big cost/decision for such an unknown...
