That's real nice. I really dig that rear bumper. Nice rig all together.
Looks![]()
Regarding the Slee caster plates; did you end up welding a bead or just left it without welding?
Salue
is that the hardware supplied with the caster plates? I'd throw some stover nuts on those.
Excellent overall build!!!!! Nice work on the wheels (second compliment). Which thread inspired the aux fan mod on your LX450?
Very nice! How long did the rear bumper take?
Those bolts have to be that short, since you have to install them from the inside of the bracket. You can not get a long bolt all the way through like you do on the driver side due to diff and panhard rod bracket interference.
The thread does not go through the nut all the way, but it is a fine thread 10.9 bolt. We could have opted to go with a thinner jam nut, but those are just about impossible to find in the M18.
What is not right is that the flat washers should have been used with the M18 x 90 bolt on the other side. This only uses a lock washer on the outside, with no washer on the inside. This is to get the longest possible thread engagement.
I just checked the instructions and it is not clear from the current version on how to use the washers. I will change the instructions.
What's going on with this caster plate?
