I’m reviving this thread I started from 2020. I have yet to break a CV on a trail (though I now do have a front locker). I recently had to pull my CVs (both sides) to fix bad seals that were leaking. That work is chronicled
here. The original thought of THIS thread was to identify what should be carried to be able to replace a CV on the trail. This thread has identified the parts but, after pulling and reinstalling both CVs in my shop (with a lift, and all the tools), I wanted to update this thread as I’ve learned a lot doing this in my shop.
The first thing I learned is if you have never pulled a CV on any vehicle, let alone a 200, trying to do this your first time solo on a trail without internet access would be very challenging and probably just not realistic unless you have good general mechanic skill. It’s not hard to do but w/o ever seeing it done through video or in person it would be hard to just figure out in a vacuum on a trail. There are only 3 bolts plus a brake line bracket to remove. The rest is just figuring out access and how to support and move the hub as needed and how hard to pound on stuff. There is some “feel” to this. Knowing if all you need to do is pound harder or realizing that the retaining ring is hung up and needs to be aligned is important. This
video was very helpful. Still, there is a big difference in watching a video and actually doing the thing. So, if you really want to be prepared for a trail CV replacement, I highly recommend doing it first in your garage.
The next thing is tools. You need more than just the 39mm 12 point socket. This is what I used. The left is what I’d consider necessary:
If that’s not OCD enough for you, here’s a
video. Edit: Wasn't OCD enough. Forgot the 250ft-lb torque wrench, ratchet straps to hold the hub up, gear oil hand pump and tubing, and a jack stand in addition to the jack you use to lift the corner.
For parts, here is a recap:
Finally, having a copy of the FSM is hepful too (not just for CV replacement). For this just you need the torque specs for the 3 bolts:
Lower ball joint bolts (2) - 221 ft-lb
Hub nut: torque to 148 lt-lb then completely loosen, then retighten to 251 ft-lb.
