Cv boot replacement
arich
Anthony. aka arich
New York
Does anyone have any tutorial on replacing the insser CV boot? Just found a rip and ordered the replacment boot from Cruiser Dan.
Is it was straight forward as pulling out the axle, taking the CV joint apart and replacing the boot? Going to have the front end apart replacing brakes so I thought I'd take a stab at this too. First time doing a CV joint or boot.
Many Thanks.
Its do able. I replaced the axles on the Tundra. Similar IFS setup, with the exception of KDSS. Write up attached I did for axle oil seals on Tundra. For CV axle, you would need a tool for boot clamping and a brass punch rod to drive the axle in and out. Good luck.
PM me your email address. I can email you writeup. I cannot upload pdf due to its size.
