would like to do custom turbo very soon. never done one before. my knowledge is academic from reading "maximum boost" and "import tuner" Anyone know the a/r ratio (cold and hot sides) of the t4 turbo used on the safari intercooler? what turbo is used for AVO? what about MAF? if you were to use one of the t3/t4 hybrids on ebay ($200 new) which a/r ratio to use
Any reliabilty problems forseen to extending the current oe 2 piece exhaust manifold back up 130 degrees to the turbo? (so turbo in same location as the safari and MAF turbos) do you think if I bolt this extension piece to the current 2 piece manifold it will hold of or will the extension need to be welded to the current manifold?
need links to yomamas safari pics/instructions as i cant get at yomama.net
need pics of intercooling ducting besides the cool photoman pics
anything wrong with using 2' mufler pipe for intercooler ducting-i like it cause i can weld it without couplers? i have access to some 2' aluminum
anyone know where I can get cheap couplers?
i am considering using threaded pipe elbows as weld els. will cut off threads of corse. have read of people using these.
wont use egt, booste guage, watercooling, engine management for now to hold back cost. will use cheap LED a/f ratio. will use cheap BOV. will use remote wastegate
please help and be critical if needed
