Current state of the art for replacing sun visors from other donor vehicles?
Patrick,
I started this thread on sun visors a while back. LS 400 seemed like a good call. Fast forward a couple years and our daughter's in town with her 97 (bought from us). I decide to surprise her by swapping out her sagging visors while she's on a quick trip out of town. Snag a pair of tan LS400 visors. Recolor them grey with SEM. Painstakingly pick the pin connectors out, swap connectors and go out to swap them in on a freezing, rainy evening. I've got about 3 hours into it by this point with the drive to the You Pull.
Mount the drivers side aaaaaaannnnddd. Nothing - vanity light won't come on. No power? Yes, power at the connector - both sides. Check the bulb - good. Remove the visor, open up the connector, remove the pin connectors thinking they got opened up, pinch them tighter, reassemble. Nothing. Remove the driver's side again, bring inside and remove the light assembly. Direct power to the bulb contacts, and the bulb lights. Power to the pin connectors on the visor pigtail and no 12 at the bulb contacts. What the heck? I'm now into it 4 hours. I'm starting to think I've grabbed the only nonworking LS400 sunvisor in the free world as obviously there is an internal failure. I nearly cut them open with a knife just to see what broke but get randomly sidetracked with a phone call. Non mounted passenger side works fine. Into the trash go both freshly painted visors.
In an effort to get this project done before she comes back, I dive back into MUD, looking for other visors I can snag (RX300?). Planning to do the whole thing over again - 90 minute drive round trip, recolor them grey, get them mounted. Quite randomly, I read your comment above that the LS400 visors ONLY WORK WHEN FULLY RETRACTED. Run out to the garage and pull the visors out of the trash can. Sure enough the driver's was 1/8 inch from retracted and it works fine. Passengers was fully retracted, which is why its vanity lit up fine. So I owe you big. These will be installed this evening with about 20 minutes more work. Thanks!!
Patrick,
Glad it finally worked out for you!
It is a little annoying the light won’t turn on unless fully retracted, but fortunately I almost never use the light. The sun visor is a perfect color and fit otherwise.
Patrick,
Hahaha I have to laugh. I had the same issue and didn’t know why. Couldn’t figure it out and through my hands up. Didn’t care if they didn’t work though.
Looks like early model 80s have a different sun visor setup. anybody tried the ls430 mod in a 3fe 80?
Early model 80s have the screw on the thin side of the clip and are prone to split. They all work with my kits, just order the right one.
I also make replacement clips for the early models.
I have a '94 with the "early" style visors, and have converted to the LS400 visors with Solve Function clips and adapters. They work well. Just make sure you order the correct "version" (early vs late style) because they aren't cross compatible.
Also the early ones (as in my 3/92 DX 80) are covered in thin vinyl type plastic not furry cloth-like material. I've tried to source replacements for mine (my 80 has a rooftop console btw) but they're totally NLA.
  • Like
Reactions: ppc
I have a set of LS400 visors arriving today.
I have a 08/92 built 1993. What do I need from you to make these work?
Thank you.
Should be the ticket , I picked tan color.
I’d need gray. This is what I have now.
Early and Late are based off of vehicle..
Early has the hole through the thin part of the visor clip.
Early Dash, no Airbag "We die like Men"
Late has the hold through the thicker part of the clip towards the front of the vehicle..
Late dash, Airbag. "I still have Landcruiser parts to install"
Can the non-clothy type of sun visors still be sourced at all? Last time I tried all the known part numbers basically nothing came back as available. My 80 has the roof-mounted factory console.
Can you post a couple pics of your installation? I’m trying to install mine and it’s not really working out. I may have wrong visors or I’m just too dumb to figure it out.
