Cummins 6BT Fuel Pump Removal (Real Time)
I had a throttle shaft bushing that was a little loose. It will need new bushings.
With 240K miles on it he recomended that I do the full rebuild that will last another 250k miles.
He knows injector pumps so I'm taking his recomendation.
Even the techs who nothing will tell you that:D
But I tend to agree,once they are off and you have to open them up,you may as well go the whole hog and have everything checked/fixed.
Sometimes there is a big increase in power after a rebuild,particuarly in the higher rpms:cool:
D',
I think you're getting a good deal on a total rebuild of your IP. A rebuild here in Austin would be around $1k+. Make sure all the o-rings are Viton or equivalent and you should be good to go for another 200k miles.
My leak was behind/under the adnoid? It was not suppose to be leaking there.
After I showed it to my local diesel shop guy, he refered directly to the injector pump shop. He even called the injector shop between the time I left his shop and drove 6 blocks to the injector pump shop.
Here are the pics of the hole it goes in.
I finally got the pump mounted. That back bottom nut is a pain. I had to moidfy the wrench again. I tried to buy the correct wrench but the Matco, Snap-On, Cornwell, Mac tool reps do not carry them. They can order them and it would take 10 days to get.
I should have it up and running in a few hours.
Project is done.
I took it for a test drive and it seems to blowing black smoke a bit.
more power .. or less .. ?
how much boost .. ?
