CT 90 spare gas can holder
Discussion in 'MX / ATV / UTV' started by valentine, Feb 20, 2009.
  1. valentine
    valentine
    488
    Albums:
    2
    46
    Mar 23, 2003
    Vancouver, WA
    So I went down to Walmart today (on Dieseldog's '84 CT110 of course:D) and bought a one gallon gas can with the fancy spout for my CT90.
    On the way home, I was thinking of what I could make a carrier out of. It needed to be something I had laying around the garage. You'll see in the pics that my garage is messy & I have alot of crap laying around, so I knew that sooner or later, I'd find something that would work. :doh:
    The main reason for my trip to walmart was to pick up some motor oil since I was in the middle of the "performance" cam install and needed oil for an oil change after I drove it around the block a few times.
    While I finished the cam install, the spare tank holder was still on my mind.... I happened to look down to find what was left of my old 500W halogen work lamp laying by the garbage. The wheels started turning....
    With a little bending I got a pretty good working frame.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. valentine
    valentine
    488
    Albums:
    2
    46
    Mar 23, 2003
    Vancouver, WA
    Here's a "dry fit" to see how everything looked.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  3. valentine
    valentine
    488
    Albums:
    2
    46
    Mar 23, 2003
    Vancouver, WA
    I wasn't too happy with how it set on the frame. The ass end of the gas can wanted to slide toward the bike. So I went looking around again & found a piece of sheet metal that was from an old vent hood I threw out a couple years ago.
    With a little bending, grinding, drilling, and some self tapping screws I got it to fit just right.
    Notice, I bent a tab up on the front inside corner of the metal. That keeps the gas can from working it's way toward the bike.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  4. valentine
    valentine
    488
    Albums:
    2
    46
    Mar 23, 2003
    Vancouver, WA
    Done!
    I just extended my range by 100 miles. :lol:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  5. yooper
    yooper SILVER Star
    4,133
    Media:
    6
    Albums:
    1
    286
    Sep 17, 2002
    Da Yoop
    My gut says it's going to flex into the wheel with a full can of gas and a little bouncing. If you can tie the bottom rear into the fender again you could stiffen it up enough to prevent that I think.
    My gut also says the two screws holding it on isn't enough - the tube itself is going to wear out and fail there maybe. I have no solution to offer.
  6. srplus
    srplus Walked with the Dinosaurs
    500
    46
    Aug 30, 2004
    earth
    I would say two washers front and back... the one closest to the fender being larger that the nut would normally use. You could arc the one on the tube for a good fit.
    My real concern was whether the nuts inside the fender would stick out too much to clear the tire on big bumps. I would turn them around and put the nuts on the outside and trim off any excess bolt with a stainless steel hacksaw blade.
    My second thought was that it would be a mess if you grazed a tree on that side and the tube bent in and cleared out a few spokes for you.
    Like Yoop said if there is a third place for attachment on the fender... that would be a good thing. Excellent idea and it will work fine. :clap:
  7. Doug_S
    Doug_S
    880
    Jul 19, 2004
    Olympia, WA
    I'm sure that you're aware that Honda already makes an auxillary gas can for the rear of the CT series. I didn't see one on the 110 but it may already have one. It's always nice, though, to have something home made on the bike so I understand what you're doing...
  8. valentine
    valentine
    488
    Albums:
    2
    46
    Mar 23, 2003
    Vancouver, WA
    Yep the 110 has one. I wonder if Dieseldog would notice if it was missing when he picked the bike up from me. :hmm: :lol:
    I actually picked the red 110 up from Olympia last fall.
    I'd rather not pay the price for the whole set up. I have just over $6.00 (the price of the gas can) and a couple of hours of labor invested in this one . :D
    :cheers:
  9. valentine
    valentine
    488
    Albums:
    2
    46
    Mar 23, 2003
    Vancouver, WA
  10. valentine
    valentine
    488
    Albums:
    2
    46
    Mar 23, 2003
    Vancouver, WA
    *edit*
    I'm an idiot sometimes. I need to change the attachment points of the brace. (thanks for pointing it out Gladly:D)
    I will post pics when done with the new and improved brace. :cheers:
  11. yooper
    yooper SILVER Star
    4,133
    Media:
    6
    Albums:
    1
    286
    Sep 17, 2002
    Da Yoop
    Dude. :doh:
    Either tie it into the fender down low or to the cargo rack.
  12. yooper
    yooper SILVER Star
    4,133
    Media:
    6
    Albums:
    1
    286
    Sep 17, 2002
    Da Yoop
    [​IMG]
    My ideas:
    - Find a piece of tube just barely bigger than the fuel can rack tube and build a plate bracket with a section of this tube on it that attaches to all of the factory holes in the fender. You can attach to section of tube to the plate bracket with conduit half round fittings or something similar. Then just slide the fuel can rack into the tube bracket from behind.
    As you can imagine this still lets the entire rack rotate up and down, so you need to add a brace for this. The second brace is a better place to put this stress than the main mounting point.
    - You have two choices for the second brace: The fender lower down, or the cargo rack. The cargo rack will be stronger and offers you better geometry since you can attach the outer corner of the rack to it. The attachment to the cargo rack can be via some kind of clamp that is easily opened or closed around the tube of the cargo rack, making the whole thing easily removable.
    :cheers:
    I just heavily edited that.
  13. yooper
    yooper SILVER Star
    4,133
    Media:
    6
    Albums:
    1
    286
    Sep 17, 2002
    Da Yoop
    If you wanted to make it really strong and give yourself a few more options for attachment you could try to find a factory aux tank fender bracket. Look at the one on the 110 and you'll see it's pretty beefy. They are hard to find. I'd give you mine but I sent it to Jman already.
  14. valentine
    valentine
    488
    Albums:
    2
    46
    Mar 23, 2003
    Vancouver, WA
    Version 1.3
    The original design had too much flex and not wanting to drill any holes down low in the fender, I went back to the drawing board.
    I had some ½" steel laying around the garage so I copied the shape of the flat spot on the rear fender as much as I could for looks. I clamped it on and with a pencil, marked the mounting holes. They are the vertical ones with the captured nuts on the inside of the fender. I drilled them out with a 1/4" drill bit, found metric bolts that were the perfect length and mounted it. I marked the horizontal holes, then took the mounting plate to my parents house to use my drill press that my dad has been borrowing for the past two years :lol:
    I drilled out the horizontal holes 5/16 so I could tap them out for 3/8 bolts. I didn't want to through bolt through the fender, so I figured I'd go this route.
    I also sleeved the tubing with ½" sch40 pipe, squished it with my hydraulic press to somewhat of an oval shape so it would have a flat spot where it mounts to the mounting plate. I took measurements of where the threaded holes were, drilled through the pipe and voila, it's done. The 3/8 bolts are just long enough that the threads stop probably 1/8" before touching the fender. I also made the holes line up with the holes that were already in the fender just in case I couldn't find bolts short enough..... :D
    I also cut a relief down the length of the pipe right where the weld was. It was just too tight of a fit over the tubing.
    [​IMG]
    [​IMG]
    [​IMG]
  15. valentine
    valentine
    488
    Albums:
    2
    46
    Mar 23, 2003
    Vancouver, WA
  16. Jman
    Jman
    1,550
    177
    Feb 20, 2003
    If ya don't know, I ain't tellin'
    I agree with yoop's assessment and was going to say pretty much the same thing. The stock bracket is very beefy, and attaches to the holes in the fender on the left side and the right side AND where the rack attaches to the fender--it is very rigid, and it carries less than a gallon. A gallon of fuel on that tube will cause tube fail fairly soon, I would think, and would probably bend the fender before it failed. :frown:
    Can you fab a tray that has arms that attach to the bottom of the rack, and extends behind it, above the tail light? Angle iron, with holes drilled in it, and U-bolts? With an edged tray attached to the arms that the can can sit in?
  17. yooper
    yooper SILVER Star
    4,133
    Media:
    6
    Albums:
    1
    286
    Sep 17, 2002
    Da Yoop
    The bolt heads are gonna wear holes in your fuel can. :flipoff2:
  18. valentine
    valentine
    488
    Albums:
    2
    46
    Mar 23, 2003
    Vancouver, WA
    I know. I need to either find different style bolts, or grind the heads down. This is just stuff I had in the garage. I still need to take it all apart and spray paint it. :doh:
  19. valentine
    valentine
    488
    Albums:
    2
    46
    Mar 23, 2003
    Vancouver, WA
    If I had a small welder I could and would build something more extravagant. The only welder I have is an old 220v stick welder. I'm not good enough on it for the small welds it would take.
    Remember, this mount is not set in stone. I can and will change it if I see the need. :D
  20. Red Herring
    Red Herring
    774
    Media:
    22
    Albums:
    3
    Feb 28, 2005
    Victopia BC
    If you have to build it, mount it to the rack would ya. Like the others have said, DON'T bolt it to the fender. It is not nearly strong enough. You could hang brackets down from the rack, and use the fender as a tie in to support the bracket, but you can't use the fender to support weight. You are asking for trouble in short order.
