Cruiser Trash Parts - Products & Sales - 60 Series niche solutions
CruiserTrash
Supporting Vendor
GOLD Star
Denver
Website
cruisertrashparts.com
I've posted here a few times but figured I should consolidate into one post. I've been around a few years making niche 60 Series parts as a side hustle when I'm not at my day job, being a dad, camping, or playing music. So, without further ado...
It's time for the 2024 Summer Adventure Sale. This is something I do every July in the run up to Solid Axle Summit, and yes, my sale is the SAS on purpose! Summer is the time when we're out using our trucks, breaking things, finding flaws, and generally upgrading, so I give you 15% off your entire web cart full of my doodads. No limits, no strings, just use the code "20SAS24" at checkout. This sale runs through Monday 7/22 at 11:59PM MST. That's one week from today.
Link ---> Cruiser Trash Parts
Sale runs all through the weekend and Monday until 11:59PM!
Last day for the Summer Adventure Sale!
Panels, fusible link replacement kits, headlight upgrades, problem solvers, and the occasional used part. check it out: Cruiser Trash Parts
Here's a little slideshow of some of the doodads:
A new product hit my web shop today - this one is ultra niche! Did you swap a Saginaw power steering pump into your 60 Series? Or how about on your 40 or 55? Or do you have an engine swap that uses a Saginaw steering pump? It uses a boring old Dorman cap and on the 60 Series you lose that cool "Toyoda" cap. Well, now there's an adapter for that. It's the little things, right?
You can find the Toyoda/Saginaw cap adapter here on my web shop.
You supply the original 60 Series Toyota cap/dipstick assembly and a Dorman 82581 cap/dipstick assembly (so long as that fits your Saginaw pump, the adapter ONLY fits that Dorman part!), I supply the adapter and detailed instructions. The adapters are made out of a heat, impact, oil, and vibration resistant urethane resin and the fit is tight enough that the caps don't spin on each other (if there's movement, a couple dabs of RTV will do the trick). This is a bit of a DIY project as you have to free the "Toyoda" part of the cap from the lower dipstick portion, but there's an explainer in the included instruction sheet. Once the lid part is free it takes about one minute to fit everything together. If you don't have a Toyoda cap/dipstick assembly you can get that used. I suggest the Classifieds section here on Mud, calling Classic Cruisers in Colorado, other parts yards on the web, or the numerous people on the various 60 Series Facebook groups who part out trucks.
Deluxe Panels are in stock for most variants! These are brown interior panels for the cargo area and tailgate of all 60 Series trucks. I have some b-stock Deluxe Tailgate Panels as well - these got some minor scratches in handling at the CNC cut shop and are marked down accordingly. Of course my black ABS panels are in stock as well. All of the panels are robust, simple solutions for replacing your factory panels that are either falling apart or are too fragile for your usage (like loading cargo or camping).
Some iterations of the Deluxe brown panels have white linework and my Cruiser Trash Parts logo, and others have no logo and brown linework. I will be switching over to the no logo/brown lines soon as stock on the logo/white lines draws down - but either one looks great! Note, these are the same color in the photos below. Lighting and camera are different.
Here is an example of a scratch on one of the b-stock Deluxe Tailgate Panels:
And here is the ABS Cargo Panel. I also have matching Tailgate Panels for the ABS!
Be aware that there are EIGHT variants of the Cargo Panels through the 1981-1990 range of the 60 Series, so if you're not sure which to get just message me. All Tailgate Panels are the same, so those are one-size-fits-any-truck. I can also provide custom panels for aftermarket 3-point rear belts, windshield washer fluid hole delete, and so forth. Note that I cannot provide panels for aftermarket speakers as there are WAY too many on the market and the fit between the bodywork supports is very tight in most cases. These panels are easy to modify at home with a drill and a jigsaw.
New products alert!
FJ55 rear window gear is almost ready. This will be on sale in the next week or two.
Early FJ40 dome light brackets are ready to go and live on the web shop right now.
60 Series Fire Extinguisher Brackets are almost ready. Initially these will be for early (81-84) trucks ONLY. The rest of the 60 lineup will follow, with 80 Series after that.
But wait there’s more….
Starting tomorrow at 8AM through 11:59PM Monday night … save a bunch of dollars on my trash Land Cruiser gear! The discount codes combine! This includes the new 40 Series dome light brackets and will include the fire extinguisher mounts when they go live (by Wednesday).
Panels have an extra big discount. I’ve got a big stock up on those currently and want to clear some out. There’s also a b-stock Deluxe Tailgate Panel with an already low price that’s another 25% off. It has one small scratch from fab.
Thanks for all the orders so far! Y'all are keeping me plenty busy. One more day to go...
Today (Monday) is the final day for the Black Friday/Cyber Monday sale at Cruiser Trash Parts!
25% off all panes with code PANELSTURKEY
15% off everything else with the code TURKEYWEEK24
Codes can be combined!
--->Check it out here<---
F/F.5/2F/3F/3FE timing gear oil nozzles are discontinued. I recently resurrected this with a local cruiser guy. You can get one here.
A perfect inexpensive touch to add to your engine rebuild or refresh.
Got the nozzle! Beautiful reproduction of an unotainium part. Cheers!
Better? (Guess the finger...)
:p:D
@Spike Strip I thought that was you who ordered. Thanks!
@OGBeno Duly noted on the part number. I’m going to put that on the website. 🫡
s***, I’m good. I already put that part number in the product description 😎
Always one step ahead … of myself … because I’m really forgetful.
In other news here’s a teaser.
This mystery thing is very close. Waiting on a few parts to arrive and one final tweak.
Still here, still doing the thing!
Fusible Link Replacement Kits
Fire extinguisher brackets
Rear Seat Bumpers
Koito headlight upgrade kits
High beam indicator modules
Laser cut ABS cargo panels
And more!
Cruiser Trash Parts - https://cruisertrashparts.com/
It almost slipped by me this year since I’ve been busy with an engine swap and other things, but I didn’t forget: the 2025 Summer Adventure Sale starts today! 15% off EVERYTHING, no code needed, discount automatically applied to your cart at checkout.
Please note some items may ship after I return from Solid Axle Summit. I will do my absolute best to get orders out the door prior to leaving the morning of 8/1, though.
