Cruiser part needed
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
I'm missing two parts to get this thing looking good and I thought I would ask local before I went to look other places. First I'm looking for the outer mounting ring for a headlight. This was the same from about 69 to 83. It's what actually holds the headlight on the outside to the inner ring.
In the pic below you can see on the right the missing headlight. It is the ring that would be used to sadwhich the headlight to the inner ring pictured. Should be a stock item on 40s and 55s. And I already have the trim piece that is shown on the passenger side.
Someone with a couple parts vehicle must have one somewhere as it usually doesn't go missing like mine.
Also need the lower portion of the steering colum cover. The upper one is on the seat but the lower section is missing.
Thats it so far.
Also need a turn signal for the drivers side as shown in the first pic. I have new lenses but just need the signal part.
Is it the larger square turn lights with the yellow lense on the side or are they the small rectangular ones that are most common on the pigs. I have several of the rectangular ones.
Hey I have a bezel from a 40 so I may have the piece you are lookin for...I'll try and pull it out this week and look at it.
Got the lower steering cover if its the same as a 40. the trim ring on the headlight can be had at Advance auto. Have a old one if you had rather have but it may have a little rust. Let me know and I can send by Alex.
Alan I'll take the steering cover. Thanks
You wouldn't by chance have an old drivers side front turn signal laying around would you. I don't even need a lens as I already have both of those.
Man I cannot wait till the swap meet.
And Chuck I'll take your trim ring for the headlight.
Hey Marshall
You may want to shoot Jeff Busby an email the Upstate Cruiser originator of the pig. He has lot of parts I do believe. His email is : busbyfam@cetlink.net
-Travis
