For those of you following my lx 450 overheating saga, I finally insisted that the clutch fan be changed. The truck seemed ok for a couple of hours today but then started to get very hot (3/4). I did the home headgasket check (bubbles in overflow at 3K rpm) and got some bubbles so I am assuming that I need a headgasket. I do not want to go back to the dealer for a new HG both for reasons of cost and because they appear to be incompetent.
Anyone have any recommendatons for independent Toyota mechanics south of Boston, MA?
Also, can anyone explain how a compression test would show the motor to be fine, I have no coolant loss or slime on the oilcap, but the car would blow bubbles at 3K rpm apparently indicating a headgasket leak? Am I mistaken about the bubble test? Symptoms are: cars seems to run fine around town w/ or w/o AC but when I maintain a sustained speed of 40 + mph, the temp goes to 3/4 and will not come down. Truck is a 97 w/44K miles, thermostat, coolant and fan cluth have been changed.
Thanks for any help. I am at the end of my rope here.
Matt
Matt
