Cruise control is dead (1 Viewer)
aus
Hi all,
I have two issues
1. Coolent temp seems to wonder sometimes
2. My CDL doesn’t engage.
I replaced my coolent temp sensor, the gauge in the cluster and when I started it this morning after 3 weeks it worked perfectly. I went to restart it… and it did its thing but then sat back to where it was meant to go,
Cruise still worked at this stage.
CDL issue - I replaced a switch on the box and also replaced the relay. Neither of these solved the problem.
This is when the cruise control stopped working. I did remove the CC computer to get to the relay but put them back as they should be.
Rechecked the speed sensor - gave it a good clean no luck…
Can’t work it out. I’m pretty sure the cluster I have doesn’t show me when the CC is active so I can’t fault find that way (either way there is no light).
It’s very annoying I need a wizard to sort these gremlins out.
Any ideas what else to check?
Should update to say.
Fixed - was the connector into the controller being loose
