I'll definitely being doing the clutch mod, so count me in. Anyone know of a hobby shop up in the north part of the Valley? I'd be happy to pick up some fluid.
Ed
Ed
Howdy! Fan clutches were developed 20-odd years ago for several reasons. At hiway speeds, there is often enough air flow that the fan is rendered useless. If the fan does not spin up to speed when the engine is cold, then it will warm faster. Less rotating mass MIGHT improve gas mileage. The fan is quieter when it doesn't spin so fast all the time. Fixed (solid mount) fans work just fine. They were the standard for many years. I have seen fan clutches converted to fixed fans when they were not working properly. This was done by running a couple of sheet metal screws thru them and jamming the bearings. Obviously, this is not repairable, but it is an option for an overheating engine. Johnok...here's a general question.
If a fan clutch is designed to allow the fan to spin at a percentage of the speed of the shaft then what would be the downside of eliminating the clutch all together (my old 442 didn't have one)? You would add a spacer and the fan would spin at 100% of the shaft. Max with a clutch = about 85%-90%. I could see an issue in the very cold regions. Another benifit would be less rotating mass on the water pump shaft.
... I have seen fan clutches converted to fixed fans when they were not working properly. This was done by running a couple of sheet metal screws thru them and jamming the bearings. Obviously, this is not repairable, but it is an option for an overheating engine. John
Looking back it the list we are looking at, phxtlc, grrlscout89FJ62, Epic Ed Rob & Rob wanting to do the clutch mod? We can probably do a few more, if you want to do it post up so we have our poop in a group.
I wouldn't trust it. The blue hub from Toyota is the nicest clutch I have seen and priced right, the only one that I would put on an 80.
