1977 with 2F engine. A couple of times now I've found if I'm on the highway for 1/2 hr or so and have the truck running around max speed 55ish, when I get home or work and turn it off, the engine gives a couple of knocks then a loud hiss for about 2 seconds. Has only happened 2-3 times. One day it did it twice in a row, two different trips, one soon after the other. It was about 90* and high humidity. Engine was running a little warm, had just filled the gas tank. Thought maybe driving it hard and the heat/humidity was causing the issue. That was about 2-3 weeks ago. Today, about 80* light humidity. Was on the highway for 30-40 min. Engine temp stayed right at mid gauge. Was at 55mph most of the time. Got back to the office, turned off, engine gave 2-3 knocks and the loud hiss. When I look underneath there is are no fluids anywhere. Not sure if I should be concerned or not or what I should be looking for, if anything.
