Coolant routing question (1 Viewer)
Hey there, on my 69 FJ40, I want to pull the heater core from under the dash and save it until I get around to fixing the blower one day.
I was examining the tubing system, and found that the core appears to be supplied from the intake manifold, and returns to a connection at the lower radiator hose. (Pictures below)
My question is, when I remove the heater core, can I simply plug these two passages, or do I need to run a hose that connects these two points.
By the looks of it the supply line has a needle valve on it which might allow one to turn the flow of coolant on or off which would lead me to assume a connection to the lower hose is not necessary?
Any help anyone could provide would be greatly appreciated.
You CAN cap them off, but it is usually easier to get a no-leak seal if you just put a piece of copper tubing between them and a couple of hose clamps.
