well, since some are currently in major panic mode about overheating and we are still in the tail end of the last great HG panic
, I thought I should throw out a couple of numbers to quantify the rate at which coolant is lost under -hopefully- normal operation. If others could chime in for the record, maybe we can come up with some numbers that should give a benchmark figure for folks here to determine whether they may have abnormal consumption, which may be an indication of HG and other problems, leaks etc.
Here goes:
On 9/18/05 I filled up the overflow bottle to the line (it's a '97).
On 6/29/06 -9 months and 2000 miles later- the level was down by 1/2".
There may be a slight effect of the new nose down by 1" or so. Forget that. Ground was fairly level in both cases. Not major effect either.
There is a trace of red around the overflow cap, so I may have lost a bit there. This was mostly Fall, winter, and spring, which are mild here but I did run several hundred miles recently in very hot weather, with engine temps reaching at times 220F so not completely cold weather operation either. Not a lot of miles so maybe mostly normal evaporation losses -assuming I have no leak or HG problem-.
There you go: 1/2" in 9 months / 2000 miles !
Anybody else?
(edit: all the above when cold, of course)
Here goes:
Anybody else?
