I installed a 60 series mid 80s dizzy and ignition into my 8/1973 FJ40 with an F motor. It runs pretty good with the timing set at TDC, but the vacuum ports on the dizzy and the carb are closed because the carb is vacuum retard and the dizzy is vacuum advance.
There was the kit from SOR that you can replace the carb's base from the 1F with the carb base from a vacuum advance 2F carb. It is no longer available from SOR
Can I find a regular 2f mid 80s carb and remove the base on it and replace that with the base on my 1F carb or is there more to it? If I can do it myself I would like to learn how to do it other wise I have a few options through known Cruiser gods that can convert my carb for me Or is there still a source to buy a "kit"
Tech instructions would be great.
