We'd all like to know what people had before and what you have now.
Is there a comprehensive list of the effects of different caster plates? MT just replied to my weekend email. Says theirs are equivalent to Slee's.
Slee: 4*
Metal Tech: 3.5*-4*
Ironman: 5*
Landtank: 5* + Double Cardon Driveshaft
Also, did you get an alignment? What are your caster numbers? What bushings are you using? What lift?
On top of the effects the front lift and caster correction have on caster, the height of the rear end relative to the front end also affects caster. I think that means your caster numbers are taken as is when the shop has your vehicle on the lift. Then, if your rear end goes up, it's as if you lifted the vehicle more. If your rear end goes down, it's as if you added caster, reduced lift.
As for steering that is. The front drive shaft angles are only affected by the front lift and front caster correction.
For example:
I have OME 850 front springs. 2.5" heavy lift. I have ARB bumper, winch, sliders, full length 4'x7' roof rack. OME caster correction bushings. I recently measured my springs and they are at 14 inches, compressed, with a small spacer on top. At my last, only, alignment, my caster went from 1.56 degrees to 1.36 degrees on the left side and from 1.41 degrees to 1.36 degrees on the right side.
However, since my rear end was light, unladen and with 860s, I was stinkbugging. They also measured the effect of my rear end being higher up and said that would add 0.7 degrees to the caster. I presume that means if it was level.
