Does anyone know the possible source of the sound inside the assembly?
Yup no ebrake, don't need it. I drive less than 100 miles a week. I Don't go off road or anything that the rig is capable of.But now you don’t have the ebrake?
Yeah I have an intermittent squeak that I am trying to figure out. But hard part is that it is intermittent. Can hit pot holes or seam in road and not have squeak but be driving down perfectly flat pavement and get a squeak?! Gonna start by spraying silicone lube around rubber items to see if that stops anything. Sounds a bit more like metal on metal squeak though to my ears.Checking back in on this one now that suns up and windows are down, and I look like a huge D because I still have the squeak issue...
@Pyrenees - did you ever end up getting it fixed, and what worked if so?
I'm also wondering if the sway/stabilizer bar links could be the source of the sound, anybody have any thoughts on that theory?
Its driving me NUTS! If there is nothing else I get right this year, I've gotta fix this...
I thought I had it fixed. Seems like the PO's did all the maintenance except for that this e-brake was really sloppy and barely worked. So I tightened it up and I thought that it took care of the problem, honestly. But then it came back. I still definitely think it is related to the e-brake rather than the suspension, because I originally diagnosed the issue by pulling up slightly on the e-brake handle before going over a bump and that took care of it.
In fact, I can vouch for it being unlikely to be a suspension issue for one reason: I swapped out the entire AHC system proactively when I was getting 7 grads on the hi/lo test and put a new stock LC suspension on it, straight from the Toyota dealer. The squeak over hard bumps remained. My money is on the e-brake still, but lately I'm pulling a landscape trailer that makes more noise than that, so I sorta don't care anymore, haha.
ok great feedback, thx! The FSM steps to service the e-brake are intimidating. Am I just being weak? How many bananas would you award this job...I'd give myself a 1.5 banana mechanic rating....is it in my wheelhouse? If not, is that stealership work or who?
