Yes, it will only clean reservoir. I'm not a believe in the drain and fill method, for power steering or transmission either. To me, it's like, empting a glass of sewer water half way, then filling with clean. I wouldn't drink it, would you!Really appreciate the help 01LC. I was quoted $160 for a PS flush by the dealer and even more by an independent Yota shop. I'll be doing this myself for that price. See any issue with using the turkey baster method instead of disconnecting the line? Not sure when I can make it back to the self-repair shop and I'd like to keep the mess to a minimum at my apartment.
Personally I'd avoid any additives. My feeling is there're best used when on the road as a short term fix, to be flush when home. Let the seal modifiers in the synthetics work, if they don't repair. But that's me.When you do the ps fluid exchange add a bottle of Lucas PS stop leak.
Good point Utah. I'd wait through a couple of flushes before the Lucus, may get lucky.If his was not leaking as bad as it is I would agree. If he does a flush and clean out all the gunk it's going to leak even more. If he does a flush and uses the Lucus product and it stops leaking then he bought some time for replacing the steering rack. Others that have used the stop leak have no steering problem and no leaks going on 2+ years. Seems like a good thing to me? Ideal would be replace his rack.
I'm betting on an axle seal.
