I remember reading a thread here recently about oil migrating from the gearbox to the transfer box - or was it the other way round? Apparently this is a common problem.
I have a manual gearbox which works fine but after about half an hours driving it becomes increasingly difficult to shift into fith gear. I wondered whether the gearbox could be running low on oil so checked - it was infact overflowing. Since I filled it myself, I know it was right a couple of months ago - so the extra oil must have come from somewhere.
My questions are these..
Where might the extra oil have come from - the transfer box?
What could be the possible explanations for my 5th gear becoming harder to select - I presume it has something to do with the heating of oil/gearbox/transfer box -as it gets progressively worse over time.
What is the fix for the migrating oil problem? I recall it involved linking the filler plugs with hydraulic hose..? Did someone have a photo - if anyone has info on this I would be grateful -especially if you can recall the diameter of the oil plugs so I can buy the bits...
Thanks all. Cheers, Jim
