SOLD COLORADO 1987 FJ60
Year
1987
  1. 60 Series
Colorado United States
Mileage
217
Color
Tan
1987 Tan FJ60 217k miles.
Holly sniper 2300
Resealed engine with new toyota water pump and thermostat, front timing cover gasket and seal, valve cover and side gasket. Didn't do the oil pan since it wasn't leaking but it looks brittle and original.
New distributer cap and rotor from cruiser outfitters along with plugs and wires. New 4 row aluminum radiator.
Haven't gotten around to change out trans, t-case or diff fluids yet but plan on it. Did a fresh oil change.
Its got dings and dents and a bit of bondo along the passenger side where it looks like it was used to fill a dent along the front door and fender. Its got a dash cover from cruiser corps that looks great, but is covering a toasted original dash.
Carpet is ok, but not great, rear area has a worn hole down to the insulation.
A touch of rust on the back hatch and rear fender arc. Paint is oxidized but might look decent with a wax.
Starts very fast even after not being driven for a few weeks with the sniper and has quick throttle response. I wouldn't say it has more power than with the carb but feels nice with the quick response.
Could be a driver if you wanted or a great candidate for a resto.
Comes with a good set of tires and black wheels, nice hood, a passenger fender and all the original carb and smog stuff as well as a set of front and rear gray seats and door cards. I had planned to swap it all to gray.
Selling as ive changed focus to another rig and has big plans that aren't cheap.
Im sure im missing a few things but ill add when I think of them.
7500
looks like the interior is 1987, pinstripe fabric
@sogafarm it does all the above well. Ive only taken it on 20 or so min cruises near my house and only up to about 50mph with the new sniper setup, but it did great. Got up to temp and stayed just right, steers smooth and stops fine. I like the stock wheels, but we would need to swap to the other set of included wheels and tires if you planned highway speeds or some longer mileage. The current ones are a bit dry and have some cracking but still holding air just fine.
