Coil spacer position
Texas
Quick question does the coil spacer go on top or bottom of the spring? What is the diameter if the OEM coil spring?
Thanks
Thanks guys..
Another question saw some spacers at autozone for $7 vs slee or metal tech were in the $50 dollar area. What is the difference besides thickness?
I would imagine material and quality. You could also look at OME. I can't imagine putting anything from Autozone in my suspension except name brand grease, oil etc.
There is nothing wrong with Mr. gasket spacers (usually available at autoparts stores). Tons of people using these on 80 Series rigs. If you get these for 100's you will need the ones that are flat on one side (not convex or concave on each side).
25-30mm spacers available from Man a fre, Slee, Ironman, etc are about the same as a 1" Mr. Gasket spacer.
I have OME, Ironman and Mr. Gasket spacers that i've acquired since i've been experimenting with my 100. I feel a spacer on a OME 865 spring will give you the softest close to factory ride you can get without significant added weight in the rear (if you need the added lift).
x2. nothing wrong at all with using the cheaper spacers if you get the right ones.
I suspect I will go with slew. Good reputation and product. I will look at Mr gasket also
thanks
I got some from Slee, I also bought the dif drop kit too. Now just need to find time to install.
Of noteI had to wait a couple of months because he doesn't keep them all in stock and they come from Australia.
Got mine from Slee as well, be sure to use electrical tape to secure them to the spring when you install them.
