I have been watching the symptoms for the past 3-4 weeks. I know the first obvious solution is to replace the oxygen sensor. But looking over a Haynes manual it could be several areas: fuel pressure reg., MAP sensor, EGR system, air intake system, EVAP system,etc,etc.
My symptoms are rough idle at 500-600rpms and hesitant acceleration from stop, I cant tell of any problems at cruising speeds. This symptom havent been consistant, some times the RPMs are smooth and it runs great and other times its rough and others its so rough its about to stall and the check engine light comes on. Next time I start up it runs fine and a couple minutes the light turns off.
I am also getting some rattling (my best guess at cat area) during accelerations right before changing gear.
At 140k my gut tells me to change out the oxygen sensor, but with several other options for this Code 26 how do I know its the Ox sensor?
Thanks
Chris
Thanks
Chris
