Clunking when hitting bumps (25 Viewers)
New England
Hello,
I need help diagnosing an issue. When I hit bumps I hear a clunk and rattling sound coming for the front passenger side. I have replaced the sway bar links, diff mounts and all the steering components along with ball joints. I have checked the control arm bushing yet but will when there is daylight. I will also post a video soon of the sound it makes. It really only happens (or I only notice it) at low speeds. I’m not sure what it could be from. I’ve read something with the brakes but I’m not sure what to look for there. Just need advice if there is anything else I should be checking while looking at the bushings. Thank you, any advice is appreciated.
Blown shock absorber, loose brake dust shield or brake pad?
Brakes are good for sure. Dust pan shouldn’t be loose torqued it down to spec just a few weeks ago. Might be shock absorber
Control arm bushings would be the next most likely problem area.
Yea I just checked they are blown.
Have you checked the hub bearings and CV's, also tie rods. Plenty of things up there that could be loose.
They should be good. I just put them all back into place like 3-4 weeks ago. They were torqued down to specs. I mean I could check again but I’m not sure that would be causing the problem. The shocks have been on for 288k miles same with the control arms. So I think that might be the leading issue.
while checking everything: don't forget engine mounts :-)
Maybe not the most technical way to check but just have someone rev the car while you look at the engine. If it moves anything more than an inch at most then your mounts are probably not looking so hot
