Clunk noise when front end compresses
Pensacola, FL
Guy, my 99 LC developed a clunking noise out of nowhere. It only happens when the front end compresses. Like coming over a speed bump at 15/20mph. I have a lift at home and I can’t find anything that seems obvious. I’m about to put her back on it and remove the tire to check the caliper /hub. Just because. It’s pretty loud and embarrassing, tbh. I’ve checked the skid plate to make sure all bolts are tight.
Any suggestions?
Is this much play normal? The driver side has minimal movement and without the noise.
probably a little late to this thread but that shouldnt be able to be moved at all. To remove them you need prybars if thats an indicator of how tight it should be
Coming back to close the loop on this thread, the noise was the shocks. I replaced them and the noise went away.
