Hey All,
One of my (outer) tail-lights (2000 LX470) has a small crack in it, and with a TON of rain lately, it now has a good bit of water inside of the assembly. It's also a bit dirty and gross on the inside.
Eventually, I'm sure I'll break down and buy a new assembly, but in the meantime, I'm hoping to remove it, drain the water, and give the inside a little bit of a cleanup.
Removing the assembly seems easy enough, but I'm curious how easy it is to get access to the inner plastic to clean it up? Has anyone done this? Is it a pretty simple process once the assembly is removed and bulbs are disconnected?
Thanks in advance!
Thanks in advance!
