- Year
- 1988
- Vehicle Model
- 60 Series
- Location
- United States
This is a pretty well documented forum truck. I had it shipped up from Florida in 2015. It originally started life out in Missouri before that. I basically cruise it around town in the summer and park it in the winter. Odometer shows just under 232,000. I'm not 100% sure how many miles are on the engine and trans, but I think the build thread mentions 41,000 at time of swap, so my guess is less than 80,000 on them. Original swap thread is here: Another cruiser gets a vortec
Here's the previous seller's walk around from 2015 so you can see how the passenger rain gutter looked before I sanded it down. Otherwise, truck still looks basically the same today as in this video.
Truck runs great. With the shift kit it will squeal the tires on the shift into 2nd if you get on it. Newer tie rod ends, relay rods and caster shims. AC works great but needs a recharge about every 2 years. Tach does not work – I always used Torque app over OBD2. Does throw 135/155 codes for O2 sensor heater circuit. I tested the heater circuits and they are fine and O2 sensors are working great per Torque app, so I assume it's a tuning thing. I just reset the codes when thrown and carry on.
Paint is old and faded with plenty of scratches. Stripe is just a decal that will come off easily. Driver seat is ripped under seat cover. Driver side front axle leaks at knuckle. Transfer case has a very small drip at output shaft, but never enough to need added to. Truck didn't have the reverse lights or NSS wired when I bough it. I rigged up the reverse lights to the Chevy trans wiring so they currently work and have a new Chevy NSS wiring harness included so you can wire the NSS switch and make the reverse light wiring a bit more permanent.
US Wheels Ratrod (series 68) 17x8 w/ BFG KO2s 285/70r17.
Here's most of the stuff I've done since I bought it:
2015:
Extra parts:
Here's what it needs in my opinion:
...taken off the market.
- 2003 5.3L Vortec & 4L60E w/ TCI shift kit
- Harness and ECU from Fuel Injection Specialists
- 4L60E adapters from Advanced Adapters
- Center drop headers from Advanced Adapters
- Only running front O2 sensors, no cats
- Downey front driveshaft, both driveshafts modified by Texas Truck Parts
- Magnaflow mufflers w/ H pipe
- 2” shackle lift
2015:
- Added new amp for rear speakers
- New antenna mast
- Added Blue Seas USB port to dash
- New Dashmat
- New driver rear wheel cylinder
- New tie rod ends, relay rod ends, alignment
- New rear hatch struts
- New brake master cylinder
- Sanded down and filled rust spots above passenger rain gutter
- Installed new rear shoulder belts (Toyota oem non-retracting)
- Added relays to power windows and locks
- New tensioner pulley, idler pulley, AC tensioner & pulley, AC belt, Fan Clutch
- New MAF sensor
- New front axle 4 degree caster shims & u-bolts
- New Pro Comp shocks on all 4 corners
Extra parts:
- New in box Torfab BMW seat brackets
- Black leather power 3-Series seats in nice shape
- Kenwood speakers and Pioneer bluetooth stereo, all new in box
- Lots of other bits and pieces, factory manual
- Front axle / birfs rebuilt
- Maybe the steering box rebuilt
- Rest is to taste
