Check your diff fluid
Mesa, Arizona
So in what seems like ugly trend, I am here to confess my sins.
Memorial Day weekend I drove my 93 Land Cruiser to the White Mountains in eastern Arizona. A few hundred miles round trip. On the way there I was hearing some whining from the front of the vehicle. I have long suspected that there is a vacuum leak somewhere in my 80. So while I was up there I spent some time looking it over to see if I could find a leak. Couldn't find anything.
On the way back climbing out of Salt River Canyon I realized that whine really only occurred when accelerating-- when the engine was pushing the vehicle it was lounder, when coasting it was much quieter.
So this weekend I checked my u-joints. They looked fine as far as I could tell.
While laying under the car I stared at the front end and started to try and remember when I last checked/changed my diff fluids.
Long story short---this is the fluid that came out of my front diff--- slightly less than the 2.5 qts that were supposed to be there.
So I went and bought some generic 75-90 gear oil, added the new oil, drove it around for 25 miles, and then changed it again. The whine during acceleration was still there with new gear oil. I couldn’t tell a difference in the sound with it full of fluid. But to be honest, I am not 100 percent sure that the whine is coming from the diff.
But it seems likely that the diff would be at least a little damaged from running it so low of fluid. But how would I tell?
Wow!! Any visible leaks from the diff or knuckles?
Yeah, there was some oil dripping the back end of the third member-- where the u-joint attaches-- not sure what that is called. But I also have some oil leaks and a power steering leak.
And the knuckles are looking messy.
Things I should have noticed.
It's a land cruiser, I think it will be fine.
Where u joint attaches to third member- your pinion seal is done. I replaced mine few weeks ago. Not too bad a DIY.
I have a rear pinion seal on one of mine that's been leaking for about 2 years now. My plan is to replace it when it stops leaking.
Why wait to fix it, its such an easy repair. Just pull the plug and add more fluid 🤣
So to tell the rest of the story.
I managed to score a new third member on one of the blackfriday sales. Still a lot of money, and it took two months to arrive, but the good news is that it also comes with a new locker actuator.
In the meantime, I minimized the amount the time I was driving it around. It was still whining even after replacing the fluid twice. And after being filled up with gear oil there was a definite leak from the rear pinion seal. So apparently that was the source of the problem. Or at least a major part of the problem.
My son reminded me that once towing a trailer a year or so ago we had a bunch of oil on the front of the trailer, and we did not know where it came from,a nd and I wonder if that was went it went bad.
Then had the new third member installed at Higgys last week. The gears on the old third member had sure signs of heat damage-- you can see the discoloration on the tips of the pinion gear.
So I am starting to wonder what led to the failure of the pinion seal.
I only have 192k miles on my 80, with 82k since I bought it.
And I recall someone saying that it is possible to overfill the drive shaft with grease-- leading to the drive shaft not being able to compress. And in the 20 years I have owned my 80 who knows how many times I have added a squirt or two of grease to the driveshaft. Is it possible that I have overfilled the drive shaft and this is the cause of the pinion leak?
Which led to the death of my third member?
Or am I just nuts?
Jared
Or am I just nuts?
Jared
No, there is no load bearing capability to the seal, it's just a radial seal.
It's possible to damage the transfer case bearing seats however.
Age is probably the root cause.
