Today on the way to work I got a check engine light and a trouble code of 25 (over lean mixture). Got home and checked the FSM for the code and got a plethora of different things to check, injectors, o2 sensors, air flow meter, ecu, and a few others. So I checked the air flow meter as per FSM and it checked out, then checked the o2 sensor as per FSM and ended up with zero volt fluctuations while doing the first check and 5volts between vf1(vf2) and e1 at which point the FSM says "Repair (over lean) WTF does that mean?
This code popped up after I experienced the roudle idle and stalling in reverse over the weekend and mentioned in previous posts. I'm thinking that this could be be the culprit and not the tranny, but I'm not ruling other wierdness out. Anyone ever get a 25 on the check engine light?
