SOLD Charlotte/NC 94 FZJ80 3X ARB Locked/37s/Gears/Armor
Year
1994
  1. 80 Series
Charlotte, North Carolina United States
Mileage
217323
Color
White
1994 Toyota Landcruiser w/ 217xxx mile. I have put approx 15,000 miles on it during the 4 years I have owned it. This has been my off road/camping vehicle. I am selling because I have another 80 and a 100 and want to get into Tacoma or Tundra for a daily. Runs good, I have taken it on multiple 4-5 hour trips. wheeled it and driven back home. Drives 70mph on the highway well.
Located in Charlotte NC, asking $15k obo
Mods:
6” Slee Lift, springs, OME shocks, stainless brake lines, sway bar drop brackets, bump stops, radius arms, double cardan driveshaft, adjustable panhards.
Trailgear HD steering kit
ARB air lockers
Center diff lock
4:88 gears
TG Longfield axles in the front
ARB bumper
ARB lights
Warn Zeon winch
4x4 Labs rear bumper
Slee belly skid
White Knuckle Off-road sliders
Onboard air tank, mounted under rear of vehicle
ARB single compressor
Huracan Fab tailgate storage
Unknown brand snorkel
Method 105 Beadlocks
Yokohama Geolander 37x12.5 17s approx 7000 miles on them
Alpine touchscreen w Apple Carplay
12” Rockford sub/amp combo
6.5 Kicker door speakers in rear
Maintenance
All maintenance has been done by Toyota Techs(J&M Automotive) a bunch of old Toyota guys since I have owned it.
I try to use OEM parts when available. I just had them look it over 11/1 for any immediate issues and did a synthetic oil change.
Since I have owned it I have had the follow done(have receipts)
Throttle cable
Tune up- wires, cap, plugs
Valve cover gasket
Front crank seal & oil pump o-ring
Replaced u-joints in drive shafts
Replaced radiator, hoses, fan clutch
Replaced front axle seals
Replaced power steering pump(reman)
Drive belts
Bypass rear heater
Replaced seal & o ring on speedo gear housing
Replaced rear rotors, brake pads and left rear caliper
New belt trim
New Grill
Full disclosure
Maaco paint job, overspray, peeling on roof. Was originally maroon so can see through in several spots where paint has chipped.
Has some rust on body, was a northern vehicle. I have treated the areas of rust in the past, could use a new coat. I have an extra hood and rear upper hatch included with the sale.
ABS light on, never had looked at
AC does not work, need new system per mechanic
Some weeping under the motor/trans
Filler neck for gas has a hose/clamps over it from a hole. It will drip if you fill the tank up fully if hose clamps are not tight.
Car had some scrapes and dents from wheeling and dents on roof that appears to be hail damage or set under a tree.
Onboard air tank has a leak at a port
If left sitting for more then a week the battery will start to get low
License plate lights do not work
No evidence head gasket has been done
Windows can be slow to roll up/down in the winter
Sunroom roof glass has a crack, been covered by vinyl by previous owner. No leaks and opens/closes fine.
Rear end makes a noise at higher speeds, been that way since I purchased it and have looked at and no issues found.
No ashtray, used to be a CB in place of it.
Bottom part of grill is cut to fit winch
Extras
Escape Gear front seat covers(no headrest)
Unknown brand rear seat covers
Weathertech floor liners
Have third row seats
Have new OEM black fender gaskets
37" Nitto Ridge Grappler spare tire(no wheel)
Happy to have it inspected by a mechanic of your choice in Charlotte. Vehicle is located in South Charlotte(28226 zip code). The Google Drive link contains more pictures of the undercarriage, body and interior. If there are any pictures or videos you would like please let me know. I will continue to upload more and plan to pressure wash the mud off the undercarriage for better pics.
94 Landcruiser Photos
Thanks for taking a look.
Thomas
Call or text
704-289-7632
