...nor is a good torque wrench.It should all be doable with simple hand tools. You will need some different length extensions and universal joint. Also, a piece of rubber fuel hose or something similar to get the new plugs going by hand. You may need to temporarily unbolt the metal heater pipes from the back of the valve cover/head to get better access for that spark plug closest to the firewall on the passenger side. A little bit of anti-seize on the threads is not a bad idea.
