Changing my alternator then bam...
Texas
IH8MUD members help me identify thoughts on this picture of a leak or is it a leak. Nothing is ever on the ground so it makes me wonder about this! PS the alternator on the 100 series is a pain in the .....
Are you running green coolant? Water pump?
^ This. What was the last thing you did that could possibly affect coolant? looks like the alt is wet too. Things get blown around in the engine bay, so finding the source isn't always straight forward.
How is the coolant level in the radiator and in the reservoir? In the proper level or do you fill it since the water pump change?
Also check the housing around the thermostat and the heater line tube. If those O-rings don't seat properly, there can be a leak and can come out from the timing belt cover.
