- Year
- 2000
- Vehicle Model
- 100 Series
- Mileage
- 267000
- Color
- Black
Hello!
I've decided to sell my 2000 Toyota Land Cruiser with 265k miles on it. I am the second owner. I'm selling because I recently purchased an FJ40 and it has turned into a huge project and expense. I had been saving up to build out the 100 Series but now that the 40 is here I'd rather work on restoring that vehicle. Clean PA title in hand however I purchased this car when I lived in Washington state. The car was originally from San Francisco before I purchased it.
Asking $13,500. Includes the FrontRunner rack. Does not include the ARB drawers. If you'd like these please add another $1,800. I have the third row seats as well. ASFIR front skid (removed for pictures) but will be included as well.
Purchased by me from a used car dealer in California fall 2021. I have owned the vehicle since. It is my daily driver so miles will continue to go up until I find a replacement car (and/or it's sold).
Who is this LC owned by? I'm 40, no kids, just two black labs. Non-smoker. My wife and I used the car while we were in Washington state for car camping and exploring the PNW. Fire roads and camp grounds. I also have a dirt bike and I used the hitch hauler. No towing. I also work remote so no daily drive to the office. When I got the car I also found the Seattle Cruiserheads group and started hanging with them. I've down some simple snow wheeling but no off-road wheeling of any kind.
RUST - some, pretty limited. spent most of its life on west coast and I was obsessed with washing the bottom of the truck off. After moving to PA the truck stayed in the driveway as much as possible and a treatment of surface shield was applied in the fall and then again mid-winter. I tried to clean some off it off (its really gooey). I washed the truck in the winter whenever possible to remove salt.
Known issues:
- third brake light is cracked
- right rear taillight has a small crack
- front passenger headlight has a crack
- front windshield has a chip (pretty much all from the same dump truck that was spewing its load all over the highway...
- driver's seat lumbar not working well
- front seats are torn (will remove covers and share pics)
- front Toyota emblem is peeling on grill
- acid rain (hard to see in current photos will show more in direct sunlight)
- misc scratches and chips
Service History
10-2-2024 PA state inspection and oil change $152
3-13-2024 reman rack and pinion, drive belt pulley, tensioner, belt, $2,113
6-19-2023 240,427 oil change
6-2-2023 240,084 miles: sunroof clean and drain cleaning, OEM front shocks, OME rear shocks, OEM medium rear springs, new rear upper links, new rear lower links, new extension support assembly, new tie rod ends, new pcv valve, new battery terminals, new radiator hoses, new denso radiator, new front inner and outer wheel bearings, seals, brake rotors, brake pads drive flanges, transmission cleaning and new fluid, replaced rear AC valve, rear cooling unit expansion, dryer assembly. $7900 all worked performed by a LC shop in Seattle.
4-24-23 238,707 new rear brake pads, rotors, and new brake calipers $659
8-25-21 218,581 catalytic converters stolen from truck, new cats, O2 sensors installed $3,082. Also paid $1,200 for a custom diamond plate skid plate/cover that would prevent future theft (seen in pictures)
7-20-21 217,880 AC charge and oil change
5-7-21 214,963 door locks working intermittently. I replaced all the door lock actuators but it was found the body control unit was also bad new BCU installed and door locks have worked perfectly ever since. Front diff fluid also changed. $1198
3-27-21 Car Toys Alpine head unit with wired apple car play $439
3-13-21 new tires LT285/75R 16 from Les Schwab
2-23-21 213,277 new timing belt, water pump, serpentine belt, 2 new keys $1,526
On top of these maintenance items I've also performed the following maintenance
11-13-2021 Replaced rear weather strip around rear cargo door. Also sealed with silicon the quarter back trim pieces to help resolve rear cargo area leak. Used black trim seal on quarter back windows as right rear was leaking a little bit under the seal.
11-13-2021 New air filter and 9006 headlight bulbs, and yellow led fog lights
12-11-21 Oil change 5w-30 mobile and mobile filter
Changed spark plugs and oil change 222,174
Oil change 227891 and Greased front drive shaft
Next oil change 232,174 done on 7-3-2022. At 231,398
7-22-2022 - installed cabin air filters, none were installed prior
Oil changed: 235,429
5-5-2023 Installed arb drawers
5-31-2023
TorFab refresh (outlined above)
6-20-2023 Oil change at Toyota of seattle Next oil change due: 245,700
9-10-23 Oil change: 247,155 Next change due: 252,155
1-22-2024 Changed at 251,924, Next oil due 256,924
3-14-25 New oil filter mobile 1, had to replace the Napa filter after visit No oil pressure, the oil pressure sensor connection was not put back on, had to remove oil filter and reroute the wire
5-22-24 Oil change miles at 255,721
Next oil change: 260, 721
new heater Ts (done this at least twice since owning)
10-2-24 Oil change 260,068 Stark’s , Next change due 265,068
3-9-2025 264,530 changed, next oil change 269,530
3-5-2025 New spark plugs , All new denso ignition coils
VIDEO
Part 1 of 2
Part 2 of 2
Known issues:
Service History
5-31-2023
VIDEO
Part 1 of 2
Part 2 of 2
