CD/DVD Player and Clock went out?? Won't Play!!
VA
What could it be? My CD/DVD Player and clock stopped playing at the same time. I just hooked up the wiring harness to my aftermarket radio. It was playing fine and then it just went out! I checked all the connections and fuses! Two fuses were blown and I replaced those, but they still don't work. Please Help! I have a 1996 L/C.
Did you check the fuses again? If you have a short or an open somewhere you could have blown the new fuses too.
Thanks, guys. Some wires were connected wrong, but now my CD/DVD/TV tuner plays fine but when I switch to the radio it doesn't play like it should. It isn't as loud (as if the antenna isn't working). What could it be?
It is pretty normal for the tuner to be a little quieter, most high end units like that have an adjustment to equal the source volume levels, check your owners book.
