- Joined
- Jul 21, 2004
- Threads
- 11
- Messages
- 51
Hey all,
I'm planning to finally install the CC bushings after driving around with marginal caster for more than a year. I understand about marking the bottom of the arms for installing the new bushings, and I have time lined up with a friend who has a big press. What I don't understand is Slee's instructions about securing the vehicle. As I read it, you just chock the back wheels and strap the axle to the front tow points. Don't you have to jack up under the frame and support the axle? If you remove the arms while the truck is on the ground, what keeps the axle from squirting out from under the truck and causing the front end to fall down?
TIA,
Paul
TIA,
Paul
