I personally wouldn’t want to close things up “too” much because some airflow helps keep fuel and fluid temps manageable on trail. I put too in quotes because that is subjective.. more airflow restriction probably means more security.I already have ARB skid plates and don't want to have to buy a whole new set to protect the catalytic converters. I was thinking about having two additional triangular-shaped panels fabricated to fit per the attached photo.
There are already existing bolt holes on both ends.
Do you think this would work as a deterrent?
You could also get a sheet of stainless cut and bent that just bolted to the top of your ARB skid. Or even two, that obstruct the areas they’ll actually cut, but not the cat body itself. If you use appropriate hardware or thread locker as mentioned earlier they won’t be easily removable, but will come off with the ARB skids when needed.
