When I was Desmogging and studying the FSM, I put more thought into this than was probably necessary. I played around with the HAC circuit for a while, leaving it as is with the vacuum leak below altitude, with a blue VCV, with the green as limiters to the leak, with the port on the carb capped, and finally decided capped was the best route for daily driving at my altitude (230). I wanted to keep the HAC for altitude trips and didn't want to pop the hood while heading up the hill so I just installed a switch in the dash to open the vacuum to the HAC when needed.Yes, but take in mind that the little vacuum leaks that are part of the original emissions equipment (HAC) were accounted for by Toyota when it jetted the carb. They are are not detrimental or evil vacuum leaks, but contribute to the correct air fuel mixture.
