I cleaned my 2F carb a few days ago (as per pinhead's video and repair manual steps) as I was replacing a manifold gasket anyway, so I took the opportunity to clean it. Installed a new diaphram and put it back together no problem.
Put it back together and car runs but won't idle. I have tried to follow the FSM steps to adjust idle speed but it does not matter how many turns to the idle speed screw I do, it won't make a noticeable change. The only way I can keep the engine idling is by pulling the choke to the second step. As soon as I push the choke all the way in the engine stalls.
Also, the 60 ran pretty normal for a day or so after putting back together, but now it hesitates pretty bad and I cannot drive it on second gear. As if the timing is all thrown off! Could it be because now that I have proper vacuum (fixed intake leak) the timing needs to be adjusted also? Or the distributor recurved? Is a de-smogg 2F
Any thoughts?
Any thoughts?
