My 72 fj40 has been running rich.... sooty exhaust pipe, gassy smelling exhaust, grey smoke when starting with warm/hot engine, hard to start hot (gotta pump a lot of gas to it), easy starting cold, poor performance under load/acceleration, some backfiring when at highway speeds, fuel economy is bad...around 12mpg. It idles and runs fine at slow speeds. I've regapped points, installed new fuel filter and new plug wires, new distributor 5K ago, have not rechecked timing since the new dizzy was added. Could the coil be bad? Vacumn leak?
When I look into the carb, one barrel is clean as a whistle, the other is black, sooty and oily at the bottom. What could cause this?
I've done some searches and it appears it might be the secondary diaghram. Can this be fixed without doing a entire carb rebuild? I have no desire to try a complete carb rebuild and am considering sending it out or trying the Trollhole import carb, if indeed the carb is the culprit.
I have the stock Aisin carb on an unaltered F engine and to my knowledge the carb has never been rebuilt. The truck has 130K on it.
I'd appreciate any advice. I'd like to make sure it's the carb before I rebuild or replace it. Related question... would desmogging help? I'm in western Colorado at about 6000 ft elevation and take trips regularly up to 8-9000 ft.
