Car port questions
Western Pennsylvania
I'm looking into a car port for my 2022 GX460.
Size would be 7ft High 12ft wide and 20ft long.
Question is 7ft height should be more than enough in height as I believe 6ft would be to low on the corners?
What are your thoughts?
Pictures would be sweet too!
Thank you
  • Like
Reactions: r2m
Just depends if you plan on lifting it or putting a rack/RTT on it..
If you're not inclined to haul stuff on top such as kayaks or gear that should be OK. Also might get a bit tight to jack up the vehicle for changing a tire, etc.
As a tall person I would find 7 ft. ceiling too low, a bit claustrophobic!
Same. I am 6'5" i would want at least 96".
Depending on weather you may want more overhang. I know someplaces it can hail diagonally.
If I remember correctly, my build is 7'-4" as it sits: Builds - R²M 2013 GX 460 Overland Build - https://forum.ih8mud.com/threads/r-m-2013-gx-460-overland-build.1104719/
with 3" suspension lift, 34" tires and iKamper RTT.
To be sure of the height, I need to check the sun visor. I keep a card with the overall height of my rig up in the sun visor in case I ever come to a parking garage or ??, I can just flip the visor down to remind me what it is to ensure that I'll make it a parking garage, bridge or whatever.
