Can you rotate a zerk assembly? (1 Viewer)
Charlotte, NC
My front driveshaft u joint zerk isnt lined up as it should be. The other 3 are lined up to the widest part of the u joint opening as they should be and greased with ease.
Can the entire zerk assembly be adjusted or do I need to use a needle adapter to get that grease in? Would rather not remove the driveshaft to grease if possible. TIA
It looks like yours can be rotated with a wrench. Sometimes they are molded, but your looks screwed in.
I was able to rotate it for alignment. Still get get any grease in that zerk using the lock n lube jaw coupler… Any suggestions?
