Can you rotate a zerk assembly?
Charlotte, NC
My front driveshaft u joint zerk isnt lined up as it should be. The other 3 are lined up to the widest part of the u joint opening as they should be and greased with ease.
Can the entire zerk assembly be adjusted or do I need to use a needle adapter to get that grease in? Would rather not remove the driveshaft to grease if possible. TIA
It looks like yours can be rotated with a wrench. Sometimes they are molded, but your looks screwed in.
