Here's the situation: I had driven my 80 daily and it had been running fine, just turned 238k. I get in it to go to work and it started, but ran very erratically and a knocking sound from the engine. I shut it off, checked the oil level, which was fine, tried restarting with the same result. Seemed pretty weird since I had driven it the evening prior and it was fine. Another thread pointed me in the direction of the EGR valve or affiliated parts which I spent some time diagnosing today and they seem to be functioning correctly. I decided to compression test it and while I've only checked the front three cylinders, it seems to have <50psi on those three. What type of catastrophic failure would happen just sitting overnight? Any suggestions on what to test or do next? No sign of oil in the water or water in the oil. I just cranked it over and the oil pressure needle doesn't move-gauge was working prior, although I don't know if it cranks fast enough to generate enough pressure to move the needle. So for the sake of argument, if for some reason the oil pump let go, would running the engine less than 10 seconds spin some bearings? I'm not sure that would explain the loss of compression.
