SOLD Calgary, Alberta - 2000 Land Cruiser
Year
2000
  1. 100 Series
Mileage
258000
Color
Brown
Outside Link
https://www.kijiji.ca/v-view-details.html?adId=1627409864
$21,000 CAD ($16,500 USD) Firm
Note: Odometer is in Miles, not Kilometers
This is a US vehicle, from Arizona, imported to Canada. Truck is in good condition with the maintenance up to date. Vehicle has been used to tour Alberta and British Columbia in 2022. It is smooth, comfortable, and quiet on the highway however it guzzles premium gas (manual states to use premium) as if this was 1999.
Comes with manual, Toyota toolkit, two standard keys + valet key
Maintenance done in 2022 (with receipt):
New valve cover gasket
New CV shaft seal
Wheel alignment
Oil Change (April 29)
New front calipers and rotor
Rear calliper service
New emergency brake shoes
Rear differential service (synthetic)
Front differential service (synthetic)
New heater hose installed
Coolant flush
New power steering fluid
New Air filter
New Toyota denso lock actuators (complete unit) for both front doors
The bad
Sunroof motor has seized and require replacement
Some rust on the undercarriage
Rear door locks need the actuator motor replaced (replacement motor included with vehicle)
Seats are showing some wear (see pictures)
Dent on the right side running board
Air conditioning is semi-cold
Missing two wheel center-caps
Local pickup only
